Hydraulic's
Gene Petermann
04-26-1999 15:58:16
will the hydraulic's on my WD handle a front end loader or do I need a PTO pump
William Powell
04-27-1999 08:15:38
 Re: hydraulic's in reply to Gene Petermann, 04-26-1999 15:58:16
I have a front end loader on my WD. It works fine
with the factory pump. Allis Chalmers made their own loader. Their is a picture of a stock loader
at:>Link
It's>Link amazing what it will lift. Remember, the WD
has a 3000 PSI hydraulic system.
RMD
04-27-1999 07:10:31
I've seen trip bucket manure loaders on a CA which used the tractor hydraulic pump (the CA pump is very similar to the WD pump), but there are a lot of limitations: (1) the tractor pump will only work one-way rams; (2) a supplemental hydraulic/transmission oil reservior is required so you don't leave the transmission dry when you pump a lot of oil into the loader rams; (3) the WD is a high pressure low volume system where as most current hydraulic systems are lower pressure high volume (the WD hydraulic pressures can be as much as twice that for other tractors); and (4)with a selector valve, the tractor hydraulic pump can work the loader or the hitch arms, but not both at once.
