Hydraulic question for wdtom
ED(IA)
02-08-2004 07:58:50
You suggested in an earlier post that the tractor needs to be split in order to cure the leaking hydraulic fluid problem. What would you suggest until I could get that done? I just run a blade and a loader to move snow. Should I drain the system and add new fluid or just keep adding fluid? Is it OK to run the system with a low level of fluid like others have suggested? I won't be able to do any major overhauls until next summer/fall.
Thanks!!!
