WD Hydraulics #2
ED (IA)
02-07-2004 18:48:23
Thanks Ron for your suggestions...I do have oil dripping from the flywheel dust cover. Is this hydraulic oil? What leaking seal is causing this?
It doesn't hurt the hydraulic pump to run with a low oil level?
If the plug on the pump is at the lowest part of the pump, where is the drain for the reservoir?
Once this is all done, how much oil do I put back in?
Thanks for all the help!
ED
