3pt conversion hitch
Rob Broughton
02-07-2004 09:54:53
I have a 1949 B model. I don't have any attachments for her but I can get the three point implements pretty cheep. Is it worth the money to put a three point hitch on or should I go ahead and look for a tractor with the factory 3 point? any advise would be great.
JohnF in MD
02-07-2004 14:22:19
 Re: 3pt conversion hitch in reply to Rob Broughton, 02-07-2004 09:54:53
I bougt a used worksaver 3pt for my 45 Allis B.
I use a carry-all quite frequently. I also have a
boom pole and a scoop.
You will want to add weight to the front of the tractor. I put on the Allis side weights and filled the front tires with antifreeze. You'll be able to pick up between 400-500lbs with the carry-all. Iv'e only used the boom pole once, to pick up a 1 1/2hp JD hit&miss engine, didn't have any problems.
old
02-07-2004 10:22:43
I'd say that would be up to you, you can get them for around $500 for your B, thats a lot cheaper then another tractor but you may want another tractor just to keep your B company. Your be is rated at around 22HP so a lot of 3 points equipment would be to much for it, but theres a lot that would also work on it
