Rear wheels
Dave Duncan
02-05-2004 11:06:28
How is the outer rim joined to the inner wheel weight on a series b allis chalmers 1944
steve
02-05-2004 15:06:13
 Re: Rear wheels in reply to Dave Duncan, 02-05-2004 11:06:28
you are probably talking about the 4 bolts that hold the wheel rim to the cast hub that is 20 inches in diameter and in mounted on the axle bull shaft. The 4 bolts go thru 4 half moon clamps and bolt to the 20 inch cast hub. Two of the half moon clamps have bolts that are ecentric and as you turn them they "push outward" and wedge aginst the rim. The rim has 4 bumps that the half moon clamps straddle. There is no real mechanical "bolt" between the hub and rim. The "clamping mechanism" is just these 4 half moon segments wedged aginst the rims. Some aftermarket rims are like the IH and have 4 loops welded to the rim and the bolts go directly thru the loops to clamp tight.
