AC-B throwout bearing
gregPA
02-02-2004 13:40:43
hello all. my question is, is the bearing carrier cast from steel or cast iron? mine is worn pretty bad on the ears and i am considering welding and redressing them. also anyone have a spare set of good fingers for the pressure plate that you could part with? mine are about 1/16 inch thick. seems that's pretty thin. thanks, greg
steve
02-02-2004 15:12:43
 Re: AC-B throwout bearing in reply to gregPA, 02-02-2004 13:40:43
three fingers on mine were very thin on the curved top also. i put wire feed welder on low and builtup the top. dressed them down so they are now twice as thick as the worn ones. set assembly on a table and used a dial indicator to see that all had the same standout.
gregPA
02-03-2004 03:37:40
 Re: Re: AC-B throwout bearing in reply to steve, 02-02-2004 15:12:43
thanks Steve, greg
