New to Allis
Walt R
02-01-2004 10:12:55
I currently have John Deere tractors. I have always had a soft spot for Allis Chalmers since they were the first tractors I ever drove. I'm thinking about a WD45 or maybe a CA to restore once I retire this year. My main question is how available are parts? Are the manuals still available from Allis? Is there a good aftermarket supply of parts? I thank you in advance for any information or advice.
Steve in N.J.
02-02-2004 20:38:16
 Re: New to Allis in reply to Walt R, 02-01-2004 10:12:55
Walt,
Welcome to the land of Orange! If you need any electrical parts for the AC machine of your choice, we have a complete line of electrical parts, design and build wiring systems (6V&12V) along with services such as mag, distributor, & carb rebuilding. We also build spark plug wire sets along with a full line of Ignition parts too.
Drop us a line with your mailing address and we'll shoot you a catalog right out...
Steve/B&B Custom Circuits
Tom Westerfield
02-01-2004 13:11:25
Welcome to Orange!
Among others, I have both a CA and a WD-45. The CA was restored from the rubber up. Had to get a lot of parts for things that were missing. Between dealers and individuals on the two principal AC sites, I found everything quite reasonable priced. I've done less to the WD-45, however all of the engine parts, sheet metal etc are very available from OEM, aftermarket or used. Only thing I've had trouble finding were parts for the factory power steering, which mine has. Had to have a machine shop make a pulley bearing on the pump. You've made two good choices with the CA and WD-45.
old
02-01-2004 12:10:54
Parts for allis is about the ones for the JDs some are easy to find and some can be a little harder to find. Most of it depends on how old they are and if some one has messed with them and changed parts out that shouldn't be there
