CA RESTORATION 2 QUESTIONS
JAMES (FL)
01-30-2004 16:12:02
RESTORATION CONTINUES ON THE 53 CA. 2 QUESTIONS I NEED ANSWERS FOR. I WILL BE CONVERTING THE TRACTOR TO 12 VOLT SYSTEM WITH GM 1 WIRE ALTENATOR. ANY SUGGESTIONS ON MOUNTING THE ALTENATOR TO THE TRACTOR. THERE SEEMS TO BE LITTLE ROOM BETWEEN THE MANIFOLD AND THE STEERING ARM. ALSO, THE STEERING COLUMN TUBE NEEDS REPLACING. IS THERE METAL TUBING SUCH AS CONDUIT (EMT) THAT WORKS. ALL SUGGESTIONS AND HELP ARE GREATLY APPRECIATED.
THANKS,
JAMES (FL)
Harold T.
02-01-2004 13:22:17
 Re: CA RESTORATION 2 QUESTIONS in reply to JAMES (FL), 01-30-2004 16:12:02
I have 1953- C/A with 6 volt gen. & 12 v. BAT ---12v. bulbs. Gen. keeps up bat. ok. Harold
Dave
01-31-2004 13:53:05
My Dad has, we think, a '51 (4 digit ser. #) model CA. He converted it to 12V a few years back with no clearance problems. His steering is different than most pics I've seen though. This tractor has adjustable wide front axle, the hand operated clutch on the right rear axle indicating a CA model, but the connecting link, from the pitman arm, which points down, to the L-shaped steer arm at the left wheel, runs horizontal along bottom of engine with only 1 tie rod connecting the two wheels. Is this a model CA?
steve
01-31-2004 16:51:25
 Re: Re: CA RESTORATION 2 QUESTIONS in reply to Dave, 01-31-2004 13:53:05
tractor originaly was a narrow front end and someone put a "B" front end on it. B has the gearbox with downward link, and L at the left front wheel. There were a few "adjustable" wid B built.
H.B. Hutchens
01-30-2004 17:24:54
It will fit ,had one for about 15 years, hasn't rubbed yet. I used the orginal mounting bracket, remade the adjustment arm. Also if I remenber correctly a shorter fanbelt. Hope this helps. H.B.
JAMES (FL)
01-30-2004 17:49:29
 Re: Re: CA RESTORATION 2 QUESTIONS in reply to H.B. Hutchens, 01-30-2004 17:24:54
H. B.
THANKS FOR YOUR HELP
JAMES
FL.
Dave R (MN)
01-30-2004 16:43:13
I used electrical conduit for the steering tube on my C. It's exactly the same size as the original, both ID and OD.
bryan g in mo
01-30-2004 16:28:48
your right there quite possibly is not enough room for a gm internal regulated alternator, because of the steering arm for the narrow front, I tried this on my C and the alternator would not fit , ended up putting the external regulated alternator on and wiring up a regulator.
