2WD to 4WD 6080 Conversion possible?
Dennis
01-30-2004 06:25:02
Any info or ideas where a front unit could be found would be greatly appreciated. I don't even know whether they are direct drive or hydraulic assist. I need to make the tractor a little safer to drive on hills. Those Armstrong tires that came with it are OK for going forward, but are worthless for holding back. I need to update to the best tires available.
Thank in advance,
Dennis
Lee in MI
01-30-2004 19:48:45
 Re: 2WD to 4WD 6080 Conversion possible? in reply to Dennis, 01-30-2004 06:25:02
Dennis;
Checked my AC-6060 service manual on the 4WD, the 4WD is powered by a drop box off the rear pinon. There is a gear mounted on the pinon shaft, don't know if the pinon shaft is differant that 2WD one, or just differant spacer and a gear. The drop box bolts on the under side of the rear housing. Not sure if the rear housing has a plate that you just remove to accept the drop box or not. Have a parts book coming, will check that when it gets here. Lee
Lee in MI
01-30-2004 11:44:56
The FWD is mechanical. I've got a service manual on the 6060,6070 and 6080. Don't know if the trans is differant or has the provisions for the gear box for the FWD. Will look it up later and repost.
Lee
