1984 allis chalmers 6080
george
01-26-2004 16:21:30
how good of atractor 3300 hrs cab heat air original tires would like to know what it is worth. thanks
Jim
01-27-2004 14:43:24
 Re: 1984 allis chalmers 6080 in reply to george, 01-26-2004 16:21:30
We have a 6080 and a 6060 love both of them (not knocking the Ford).Ours don't have that many hours but they are good on fuel easy on and off. Have used both for pulling a 4 row planter work well. I think you wouldn't go wrong with either tractor. Jim
Brutus
01-26-2004 19:31:00
looked at one a number of years ago,seems like they had crank problems or something. i bought a new 7710 ford instead.probably isn't your best bet. i'd look for a low hour 185,there are a few out there.
-brutus-
Dieselrider
01-27-2004 15:44:57
 Re: Re: 1984 allis chalmers 6080 in reply to Brutus, 01-26-2004 19:31:00
The reason they had crank problems is that operators would leave the pto splines engaged and run all the time with the pto clutch lever in the off position. This put alot of stress on the crank through the belville springs inside the clutch assembly. If run properly they are a very dependable tractor. Agco does have a fix for any that have the floating crank problem, but it's probably a pretty expensive fix.
george
01-27-2004 11:23:47
about your ford 7710 there is one sharp with arond 3300 hrs cab air heat good tires dealer asking 17500 how good of a planting tractor would it be and do they hold up thanks,
Brutus
01-27-2004 14:13:37
 Re: Re: Re: 1984 allis chalmers 6080 in reply to george, 01-27-2004 11:23:47
excellent planting tractor. a very comfortable tractor to operate. the older ones had a pto that jumped in kind of fast, but that was corrected in the series two. engine was a little noisy, but a cab would correct that. very dependable tractor with a lot of them sold and good resale value. while i grew up on allis chalmers and have a new agco allis, i would sure recommend the 7710 over the 6080.
-brutus-
