D-17 series 4 hydraulics
B. Jones
01-26-2004 15:47:04
We have a loader (1 way ) that all of a sudden lost power on lifting. The rear 3 point seems to have full power. Today we seemed to get the lift back but it quickly lost power again. This is a series 4 with live hydraulics. When it lost power, I though I could hear an Oil sound. Are there any O-rings or gaskets that could blow out and cause this? We have 15-40 oil in the hydraulic. Do the 3 point and the loader use the same relief valve or does each have its own? We strain the hydraulics quite a bit by lifting Large hay bales. Today it lifted one several times and then all at once lost most of its power
Scott(MO)
01-26-2004 16:32:57
 Re: D-17 series 4 hydraulics in reply to B. Jones, 01-26-2004 15:47:04
Hello, Our D17 series IV did the same thing while hauling big bales. It's been some time ago , but I believe we lost power on the loader but not the rear forks (same as you). If I'm not mistaken it was the pressure relief valve that caused it. I'm not sure if the 3pt and the remote hydraulics have a seperate relief valve or not. I would think they would or the 3 point would fail you as well. The only relief valves I know of is the "Traction Booster relief valve " and the "Hydraulic Lift system relief valve". Sorry I can't give you any more info than that , but maybe one of these other fellows can give you a little more info.
Scott
