D-15 series 2 hand clutch adjustment?
steve
01-26-2004 15:43:12
How do you adjust the hand clutch to stop it for popping out mostly at wide open throttle?
RON
02-01-2004 20:35:10
 Re: D-15 series 2 hand clutch adjustment? in reply to steve, 01-26-2004 15:43:12
is it popping out in low or high range? i'll take that it is high range because mine used to do that. what i did was grind a notch out of the bracket that the spring loaded thumb button would lock in like the low range is set up to do. never had no more problems since.
