G light switch
Mark F
01-24-2004 11:30:30
Having major trouble getting the light switch on my G off of the tin instrument panel - the backing bolt just turns. I tried to temove the plastic knob to remove the switch slide bar but it just turns.. Any suggestions? If a replacement switch is available, maybe a new one is the way to go.. Thanks for all the help..Mark
Steve in N.J.
01-30-2004 21:28:24
 Re: G light switch in reply to Mark F, 01-24-2004 11:30:30
Mark,
We have an exchange program on the OEM headlight/charging switches if you think you need one. Drop us a line, be glad to help ya out....
Steve/B&B Custom Circuits
Shop- (973)697-5747
Dick L
01-24-2004 12:02:13
Are you talking about the 10/24 bolt or the nut that holds the pull rod in place? I grind the head off the 10/24 bolt on the outside and replace it with a new one on reassembly. A brake line wrench work on the nut and held with vice grips on the out side. The nut can be cut off as a last resort with a dremmel. Yoy can get a nut that will work a hadware store.
