WC/WD CLUTCH
Don
01-24-2004 08:59:02
Does the WC/WD/WD45 use the same clutch? what's the better clutch for a d-17 swap into a WC? Thanks
L Hud
01-24-2004 17:49:54
 Re: WC/WD CLUTCH in reply to Don, 01-24-2004 08:59:02
The clutches are all about the same. Some of the early WC clutches had a narrow surface. Use one with was wide a surface as you can find for the 45. The main thing is to use a 9 spring pressure plate. Most of them used the 6 spring. The 9 spring does a lot better job. Hope this helps.
