WD45 tires?
Rod
01-20-2004 18:08:06
Has any one tried using 16.9x28 tires on a stock WD45? If so what size rim? Did the tractor have enough power to turn them?
bryan in mo
01-21-2004 17:22:50
 Re: WD45 tires? in reply to Rod, 01-20-2004 18:08:06
I've got 14.9-28 on my 45 but when you have the rim adjusted all the way in they are REAL close to the fenders, so close thet they grabbed one when I was plowing.
JSinIL
01-20-2004 21:31:47
I used 16.9x26 tires/rims off a Gleaner combine. Works great, cheap, and yes it has plenty of power to turn/spin them.
Ron
01-20-2004 20:53:29
14.9x28 is about as large as you can get into a 14" furrow.... If you are going to plow with it, and still want more traction for other things, get a set of duals, with a set of 14.9x28, or 13x28 tires, and it makes a real nice loose-ground tractor...!!
mike in mo
01-21-2004 17:30:05
 Re: Re: WD45 tires? in reply to Ron, 01-20-2004 20:53:29
can you tell me just how to get duals on a wd45?
is it a kit or do i need to do some riggin.
Ron
01-22-2004 05:00:51
 Re: Re: Re: WD45 tires? in reply to mike in mo, 01-21-2004 17:30:05
The duals for a WD-45 have a spacer ring welded on the dual rim that just fits into the inside wheel's rim, and 4 over-center latches that attach to "P-Eyes" that set-screw to the power-adjust rails.. Then are pretty easy to put on and take off...!! Make it about as wide as it is long..!! Perfect for a 10 ft disc and harrow..!! A set is for sale here in Ohio for $50,oo I saw them a few days ago on YT.. I pulled a Stuck dozer out with mine once..!!
old
01-20-2004 18:39:57
I haven't done it but I'm sure it would have enough power, it would take rims at least 14 inches wide for them
Dave Wi.
01-20-2004 19:43:28
 Re: Re: WD45 tires? in reply to old, 01-20-2004 18:39:57
I've 16.9 on my 45 and it dont slow it down I did use the 12" rims witch made it quite tall,but that was what I wanted for a better drawbar highth,if you use it alot for work it'll wear out the center of the bars sooner. Best to get 14" rims to lower tractor and get more of the barsonthe ground.
Vance
01-23-2004 07:09:26
 Re: Re: Re: WD45 tires? in reply to Dave Wi. , 01-20-2004 19:43:28
Dave Wi Or anyone Where do you find 14inch wide rims to fit a WD,or do you have to make them? Thanks
