Ron
01-20-2004 20:48:55
Re: WD Coolant Leak at Piston in reply to Rick in KY, 01-20-2004 15:45:30
I guess you have not had one of these, or you would know of a common couse of leaks at the web between the sleeves at the bottom of the waterjacket...!! Probably 90% of the running AC-WD and WD-45 blocks have at least one of these webs cracked, and NO it is NOT Death to the motor.... Ofcourse, it could be an "O" ring, but probably not... If it doesnot NEED rings, DON'T tear the sleeves out of it... remove the head, and use a good power-washer to wash out the inside of the block REAL GOOD... DRY it real good, then put a Pint of Permatex Aviation Sealer down in the bottom of the water-jacket...( use a hose, so it does not get all over the sides of the sleeves)... Make sure it coats all the way around the sleeves-especially in between them... Let it set for a day, and re-install the head. It won't leak at the sleeves anymore.. Old AC Mechanics used to recommend old paint, from the bottom of an old paint can for this..!!!! ( the THICK Stuff)..!! I hope you are not scared off by this info, this info will help ya save money, AND fix it right..!! ( Otherwise, you will mess around with having the block welded and pinned) and you shouldn't have to do all that.).... You could just leave it alone, and change the oil a little more often, and never have a problem..!! Maybe even put a piece of a Horse turd in the radiator....That works as a stop-leak, too..
