Allis 7045
Joe
01-19-2004 22:33:43
My neighbor has a 1978 Allis 7045 for sale with 6400 hours. It is a clean unit with good rubber. Is this a reliable series. Is there any thing I should lookout for, ie. tranny problems, engine concerns with this model. I only have experience with the letter series allis - no idea if the 7045 is a good tractor. Thanks for your input.
TomF
01-20-2004 13:34:35
 Re: Allis 7045 in reply to Joe, 01-19-2004 22:33:43
Joe
Most of the 7000 series AC's were pretty reliable. Exceptions:
1. The early model 7000 tractors (smallest of the 7000 series) were a bit of a joke. Just warmed over 200's.
2. The 7080 and 7580 engines were prone to bottom end problems due to excessive rpm's.
3. None of these tractors started real well in cold weather unless equipped with M&W pistons. Plug in the block heater & they start OK. I wouldn't recommend using the ether injector on these tractors. Injector was tapped directly into the center of the intake manifold, and most of the ether charge went into #3 & 4 cylinders.
Have never heard anything bad about the 7045. Should be a good tractor if it's been taken care of.
TomF
