Drag a 3-pt Disc Harrow behind a Allis B?
Tommy in S.GA
01-19-2004 19:35:04
Anyone tried pulling a 3-pt disc with a Allis B? How would you harness it up? The old ones are hard to find and I didn't want to convert to 3-pt as it would be imposible to use original implements with 3-pt mounted. 5-foot would be adaquate of a disc for my needs.
Rick ('50 B, NC)
01-21-2004 06:08:15
 Re: Drag a 3-pt Disc Harrow behind a Allis B? in reply to Tommy in S.GA, 01-19-2004 19:35:04
Tommy,
I don't know how much you want to invest, but my Model B has a Worksaver 3-point hitch that only uses 4 bolts to mount to the tractor plus the hydraulic connection. Two bolts go to the fender brackets, two bolts go to the draw bar, and then the hydraulic connection. I can have it off and on in less than 10 minutes, and it works great.
steve
01-20-2004 17:34:01
Tom, im not quite sure what you are trying to do, but if you have access to a 3 point disc and want to use it on a B, all you need to do is have two heavy steel straps, maybe 1/2 inch thick and 3 inches wide about 3 feet long. hole on end of each to slide over the 3 point pins. other two ends connect together onto 1 pin on your drawbar. forget the top link. if you dont have a disc, look for an old 7 ft that is worn out, but is adjustable angle on the gangs. they still cut fine even if 3 or 4 discs are gone, or you use front two gangs and leave the back two off. we pulled an 8 ft with a C, just cant get too aggressive. 5 or 6 ft would be great.
Bob
01-20-2004 06:25:04
Seems to me it may be better to leave both alone and pick up a used disc or go to tractor supply or a similar outlet and buy a new one. If you not to aggresive in use even a cheaper model would last years. Down side, most not made in US. Just my thoughts.
