CA Transmission and Rear End
Rod Gratzer
01-17-2004 23:30:06
My CA has not turned a powered wheel in probably 10 years, everything works,( the tranny and rearend were not stuck when I hauled it home) the motor was but not bad, I plan on just changing the gear oil and that is all...should I do more???
Thanks
Rod Gratzer
old
01-18-2004 09:48:01
 Re: CA Transmission and Rear End in reply to Rod Gratzer, 01-17-2004 23:30:06
You will probably get by doing that, I've do that on a few tractors and never had any problems yet. Of course yet is the key word do you know anything about the tractor or did you just buy it. I ask because the tranny could be the reason it was parked. But I'd still just try it and go from there. Just giveing you ideas that you have a 50/50 chance on it
