Need advise
CH
01-17-2004 20:41:30
When our service manuals call for usuing varnish on a gasket, what would you use. We have more modern metheds of sealers now.
Jason
01-19-2004 04:56:12
 Re: Need advise in reply to CH, 01-17-2004 20:41:30
I like to use contact cement. I cement the gasket to the removable side of what ever I'm sealing. I would seal the gasket to the waterpump and not to the block. That way if something goes wrong and I need to remove the gasket I just take it to the wirewheel and take it off.
David Maddux
01-19-2004 03:24:52
I use a ton of Indian head, or tabers shelac on thin use. Then I also use a lot of permatex. I remember when I was a kid in the 60's, they recommended you could use it as a gasket. It does work like that in some cases. You want the non hardening type. Great for final drive covers. Dave.
M.J.
01-18-2004 16:40:40
Use The Indian Head Gasket Shellac That RB/CT recommended Or Another Excellent Product Is KW Copper Kote. Silicone Has Its Uses but a water pump gasket is not one of them.
BB
01-18-2004 13:16:49
Careful... shellac can be very messy
RB/CT
01-18-2004 11:36:50
Have used Indian Head Gasket Sealer before, reminds me of Shellac. Like Shellac,you will never get it apart without alot of work and scraping. Good Luck.
steve
01-18-2004 05:57:41
thin layer of oil proof RTV. i like the gold that is for O2 sensors, non vapor. it is better than the blue or red in my opinion.
Ron
01-18-2004 05:10:02
Some places, Shellac is appropriate..!!
I see it designated a lot...not seen varnish called for very much..
A small bottle of Shellac will last ya a long time...
CH
01-18-2004 06:38:25
 Re: Re: Need advise in reply to Ron, 01-18-2004 05:10:02
Thanks for correcting me, I meant shellac. Is it regular wood finishing shellac?
CH
01-17-2004 20:44:51
Specifically, oil pump gasket. Needs to be thin.
