wd motor or wd45 motor?
Mike (MN)
01-16-2004 16:14:19
I have a 1950 WD but after reading the last couple of posts about the plate on the side of WD45 motor I do not know if I have a different motor because mine has a plate on the right side.
the # on the engine is Wd 246992Ga
wdTom
01-18-2004 18:44:32
 Re: wd motor or wd45 motor? in reply to Mike (MN), 01-16-2004 16:14:19
I made stainless steel studs and used stainless nuts and washers.
JOHN HARMON
01-17-2004 20:09:51
Mike: I had a WD45D in which the engine went bad although the rest of the tractor was good. I also had a WD with a good engine but lots of other problems so the WD engine went into the WD45D chassis and the WD engine did have a access plate on the right side of the engine.The WD was a 1949 and the WD45D was a 1956, so parts interchange was good for those tractors .
Brian G. NY
01-17-2004 16:55:43
Your serial number fits right in with those assigned in 1950 to the Wds. A WD block has a side cover over the pushrods and the number starts with WD. A WD-45 block has no cover on it's side and its number starts with 45-. I know of no WDs (late or not) that came from the factory with a WD-45 style engine. However, when all the WD replacement blocks were used up, A-C supplied the new style blocks as replacements. So....even tho a WD may have a WD-45 style block, there is no guarantee or easy way to tell whether or not it has the "45" innards. Incidently,replacement blocks came from the factory serial "numberless".
Ron
01-17-2004 09:17:55
It is always good to know that all the parts for the WD-45 engine will fit the WD block, should you want to add that power to your WD..!!
Aaron SEIA
01-16-2004 19:16:12
The plate is on the side of a WD engine. The very last WD's had the no plate WD-45 engine.
Aaron SEIA
Rick
01-16-2004 16:42:33
Mike(MN), If it has the plate on the right hand side and the engine number starts with a WDXXXXX ,then it's a WD engine. If it is in fact a 1950 model (according to the serial number),it would have to be a WD,since the WD45 didn't come out until 1953. Hope this helps. Rick
