TELL ME THE TRUTH.
JAMES IN FLORID
01-15-2004 08:09:46
DR. PHIL SAYS, "IF YOU ARE GOING TO TALK WITH ME YOU'VE GOT TO BE HONEST." SOMEONE PLEASE BE HONEST WITH ME. I RECENTLY PURCHASED A 51 CA. THE TRACTOR HAD SEVERAL MISSING PARTS BUT NOTHING SERIOUS. HOWEVER, I FAILED TO DO A REAL THOROUGH INSPECTION, (MY FIRST PROJECT) AND NOW I DISCOVER THE ENGINE HOUSING IS CRACKED ON BOTH SIDES, THE PIECES ARE THERE, WHERE SOMEONE APPARENTLY TRIED TO FULL THE TRACTOR TOGETHER AFTER A CLUTCH JOB. IF I AM THROWING GOOD MONEY AFTER BAD TELL ME NOW AND I WILL CUT MY LOSES.
THANKS
JAMES IN FLORIDA
R.C.
04-30-2004 08:47:51
 Re: TELL ME THE TRUTH. in reply to JAMES IN FLORIDA, 01-15-2004 08:09:46
James, where are you located? I may can help with a block. I am on the Ms. Gulf Coast.
David Bacon
01-20-2004 14:41:59
James, The Dr also said if it looks like a duck and walks like a duck----- ----You probably will be a smarter duck next time. Sounds like a parts tractor. However if it was grandpas old tractor etc. that may be another consideration. Dave NE Iowa
russ
01-18-2004 07:07:52
to be honest restoring old tractors is one of the crazyest things to do , but i , actualy allof us do it ,dont make us bad one thing i want to say is go for it because at the end of the fight(busted knuckles) blood oh yeah and the empty wallet we look back and smile and of course do it again , save that old tractor and buy a block ,good luck
Ray
01-16-2004 19:31:49
I'd say just sell it,you can buy a good one for
around $900.
Ron
01-16-2004 07:51:00
A replacement engine block should not set you back too much..at least you have everything to transfer to the replacement block.. Good Luck..!! Hope you see the Light at the end of the tunnel soon..!!
Sid
01-15-2004 16:05:06
OK to tell the truth I do not know. Guess it depends on how bad you want the challenge to finish the tractor.
