Allis Chalmers questions
John
01-14-2004 20:05:52
I found an old Allis Chalmers dozer. There are decals that read 6G back by the seat. Does anyone have any info on these. Also, I have an AC tractor that I know is a WD or Wd-45 but dont know how to tell which it is. Are there noticeable differences? Thanks
Ken Neff
01-16-2004 11:43:27
 Re: Allis Chalmers questions in reply to John, 01-14-2004 20:05:52
I bought a WD-45 out of a field and have been restoring it for several years. It is finally ready to run and operate but I have discovered a problem. The foot clutch doesn't provide enough throw to disengage the pressure plate with the throw out bearing. I can readily look at this set up and have nearly 5/8" play. The only thing I can think is that I installed the clutch backwards thus not protruding the pressure plate pawls correctly. I installed the receiver portion of the cluch plate inverted into the receiver portion of the bell housing. The inner design flows with the bell portion of the receiver. does the bell of the clutch point towards the engine or the throw out bearing?
steve
01-15-2004 17:09:47
Allis Chalmers built tract type tractors in a plant in Springfield Illinois. They closed about 1980 and moved to Italy. IN that plant they built bulldozers that were called 11B, 16B, 21B etc, they also built the tractor with tracks, no blade, but had a bucket on it as a track type front end loader. These were called 6G, 7G, 12G. I would guess the 6G was about 120 HP and maybe 20,000 pounds --- that is just a guess. they were built about 1960-1970 and my memory is not what it use to be. check out the guys at ibdozing.com and ask more questions.
Bill
01-15-2004 10:47:25
The 226 cu in engine found in the WD45 has a noticeably higher head than the WD which had a 201 cu in engine. The additional 1/2 inch of stroke in the WD45 was accomodated by a longer sleeve in the same old block thus the need for a higher head.
Scott
01-15-2004 10:03:38
I'd say the easiest way to tell a wd from a wd45 is the bent shifter. The wd had a straight one. Only trick is that a few of them have been changed out, so it's not a definate. looking up the serial number on the left side of this page is a sure fire way to tell.
The wd45 first came out with the lifter cover (think that's what the plate is) like the wd, but was changed in the first year I think, so that may not be definate either.
JMS/MN
01-15-2004 16:48:21
 Re: Re: Allis Chalmers questions in reply to Scott, 01-15-2004 10:03:38
The late WD's, produced in 1953, had the curved shift lever, and same tranny as the WD45. Gears are helical cut instead of straight. All WD45 engines had the solid block, instead of the plate on the right side. If memory serves me correctly, the WD45 serial numbers start at around 146000.
Eldon (WA) [email protected]
01-15-2004 14:26:30
Where did you get the information on the plate on the WD45 block as I would like to verify that. I have 3 early WD45s and none of them have the plate on them. From what I have learned, the WD45 block is a whole new casting.
Jared
01-16-2004 17:54:30
 Re: Re: Re: Allis Chalmers questions in reply to Eldon (WA) [email protected], 01-15-2004 14:26:30
There is a serial number on the left frame rail of my allis wd or wd45(175459) and a serial number on the left side of the block starting with 45. Can wd or wd45 be told from this.
Eldon (WA)
01-14-2004 22:20:53
Easiest way to tell a WD and WD45 apart is the WD engine block has a big flat plat bolted to the RH side.
