WD-45 3-point
Mark
01-14-2004 12:25:52
Have a wd-45 with three point. Only goes up and down nothing between. Only raises with the lever all the way up and lowers only with the lever down. What could cause this? Thanks
JMS/MN
01-14-2004 12:40:17
 Re: WD-45 3-point in reply to Mark, 01-14-2004 12:25:52
Improper adjustment of one or several parts of the hydraulic system. A decal on the right side of the battery box contains the details. Same info is in the operator manual. Matter of turning screws in and out to obtain the desired result.
Bryan Smith
01-14-2004 13:28:26
 Re: Re: WD-45 3-point in reply to JMS/MN, 01-14-2004 12:40:17
Aaannnnddd you have 3 or 4 different settings with all those adjustments described - draft control (traction booster), hold position, delayed lift for cultivators, etc. You could just have it set for one of the others when all you need is the hold position setting (or draft control, for that matter).
In hold position setting when you move the hydraulic lever all the way to the top of the quadrant it raises the 3ph or remote ram until either it reaches full extension or you move the lever back to a 45 degree angle on the quadrant, then it stays put. Same for lowering. It's not like the newer systems that come up a little with a little movement in the lever, like the later model Masseys and so forth.
