WD wide front
Jim-IL
01-13-2004 20:04:05
I'm getting a wide front for my WD and also power steering. I'm wondering how tough a job will this be? I imagine the existing pedestal will be pretty heavy to handle Any tips by someone who has done this would be appreciated.
Dave Grubb
01-14-2004 08:24:28
 Re: WD wide front in reply to Jim-IL, 01-13-2004 20:04:05
Loosen the LEFT frame rail and the bolster will come out very easily. You will need to remove the the frame rail bolt for the engine forward support. If you loosen the right frame rail you will break the seal for the hydraulics at the belt pulley hole and dump your hydraulic fluid. When you reasssmble the engine lower forward support besure the tapered washer is installed so as to make a flat surface for the attaching bolt. It is also a good time to check the shimming of the engine-to-support mounting. It should be a minus .005". Is your power steering factory or Char-Lynn?
Greg WI
01-14-2004 05:42:08
I have switched a few of the pedestals but never worked with the power steering. The pedestals are pretty easy to change. I ran a cross bar underneath the frame that was blocked up to hold up the front of the tractor. Then I disconnected the steering shaft and removed the eight bolts. One time the pedestal was stuck in the channels, I used a hand winch attached to something solid to help pull it out. The narrow front can be lifted with the wheels off, but the WFE is a lot heavier. YOu can use a rolling floor jack to help lift it up and move it into position.
