snap coupler implements
Al L. in Wisc.
01-12-2004 20:22:41
Is there a difference between snap-coupler implements by tractor, or would one implement fit on a variety of Allis tractors? Thanks in advance
Eldon (WA)
01-12-2004 21:58:59
 Re: snap coupler implements in reply to Al L. in Wisc., 01-12-2004 20:22:41
The lift arms on the smaller tractors are 3" closer together. With some implements (such as the plows) this doesn't matter because the lift linkages aren't fixed. You may have a a problem with the rear blades, but some have 2 sets of holes (I drilled an extra set of holes in one of mine to make it more versatile). Most of the other implements that don't interchange don't match the size or hp requirements (or limitations) so they are not a factor.
Al L. in Wisc.
01-13-2004 08:15:36
 Re: Re: snap coupler implements in reply to Eldon (WA), 01-12-2004 21:58:59
Eldon, thanks for the reply. I should have been more specific: I have a CA and wonder if a rear blade from a WD would fit? Thanks again
Eldon (WA)
01-13-2004 08:19:48
 Re: Re: Re: snap coupler implements in reply to Al L. in Wisc., 01-13-2004 08:15:36
It will fit. If it doesn't have 2 sets of holes in the flat bar that runs betwen the two lift points just take it apart and drill another set 1 1/2 inches in from each side.
