AC WD-45 Problem
Mark Randall
01-11-2004 13:32:04
I have a WD45 that is really difficult to get in and out of gear. is there a way to fix this? Thanks
chief
01-11-2004 14:21:10
 Re: AC WD-45 Problem in reply to Mark Randall, 01-11-2004 13:32:04
try changing the top of the trans. the fork and all come out with the top. mine was just a bent fork
Fred
01-11-2004 17:25:09
 Re: Re: AC WD-45 Problem in reply to chief, 01-11-2004 14:21:10
It is hard to get another top back on but thats your best bet other than replacing the transmission with a better one.
JMS/MN
01-12-2004 12:47:44
 Re: Re: Re: AC WD-45 Problem in reply to Fred, 01-11-2004 17:25:09
Replacing the top is easier if you manually shift the transmission into reverse (screwdriver, etc), move the shift fork as well, and set the tower on to the tranny case. Easier to get that fork into position, around the shaft.
