stroker crank
larry pike
01-11-2004 12:04:14
to make stroker crank for a wd45 eng do you have crank cut and welded for alonger stroke explain process please
Chuckster
01-15-2004 06:12:28
 Re: stroker crank in reply to larry pike, 01-11-2004 12:04:14
bacicaly what they do is weld beads across your journals and put the crank in a lathe and turn it. hope this helps!!!
