PROBLEM WD 45
Mark Randall
01-10-2004 15:35:49
I just bought wd 45 put new plugs in and fired right up. But it is only running on 3 cylinders. Has hot fire to all plugs good compression on all cylinders. But it makes a popping noise out of the carb what causes this to happen. I pulled valve cover to make sure all valves were opening & Closing. ANy help would be greatly appreciated.
Don
01-11-2004 14:12:25
 Re: PROBLEM WD 45 in reply to Mark Randall, 01-10-2004 15:35:49
Did you check that you got all the spark plug wires on correctly. I recently bought a Model D grader that uses the same engine. It was running as you described. I pulled each wire on and off one at a time and discovered that two adjacent cylinders had no impact when the wires were off. I reversed these two spark plug wires and the engine ran beautifully.
Duey (IA)
01-10-2004 22:06:07
Mark,
Like WD Tom said, could be a plug (especially if they are Champions)but my guess would be a leaking intake valve. (Burned or with a piece of carbon under it.) Duey
wdTom
01-10-2004 17:28:54
I would do a compression test to see if you don't have a bad intake valve. Or before you could change the plugs around to see if one is bad even though it is new. Same with the plug wires.
