AC-C oil pump gasket
Eric Perry
01-09-2004 20:35:40
Last spring I puchased an Allis Chalmers C that was taken apart to restore. The owner gave me the new parts that he got for it which included a new oil pump. The box it was in had gotten wet and the outside of the pump was rusty, so I took it apart to clean it. It looked OK inside so I tried sanding off what I thought was rust on the mating suface of the back cover with some fine sandpaper on a flat suface. I found out this was really a thin paper gasket between the back cover and the main pump body. What sould I use to replace it? Maybe some wax paper? Thanks for any info anyone can send me,
Eric Perry
steve
01-09-2004 20:51:53
 Re: AC-C oil pump gasket in reply to Eric Perry, 01-09-2004 20:35:40
the gasket is supposed to be of minimum thickness so the pump dont stick and drag. you assemble the pump shaft center shaft and leave the cover off. lay a straight edge across the end and see what clearance is. adda gasket about .002 thicker. normally this is a piece of paper like white typing paper. you might need a piece of construction paper on an old pump. not sure i would use "wax".
Eric Perry
01-12-2004 19:22:31
 Re: Re: AC-C oil pump gasket in reply to steve, 01-09-2004 20:51:53
Steve, Thanks for the reply. I'll try a feeler gauge this weekend and see how much I need to clear it.
