Valve stem hole size for WD rim
Shawn Turner
01-07-2004 20:33:26
Rear rim on our WD had a large hole around where the valve stem is located. We were given a rim with much less damage by a fellow AC collector, so we could use the original for "parts."
Valve stem hole rusted out on new rim too, but not nearly as bad. I've got the rim in at my school's shop, cut out rusted area and patching it up nice, almost good as new, but it needs a hole for the valve stem.
Our tire tube's stem measures 1/2 inch. Is this the size hole I should drill, or is it a smaller hole for a snug fit?
Thanks!!!
Shawn Turner
Ottawa, Kansas
Mike IA.
01-08-2004 04:44:19
 Re: Valve stem hole size for WD rim in reply to Shawn Turner, 01-07-2004 20:33:26
You don't want to go any smaller or it will cut into the rubber on the stem. After you drill the new hole make sure there are no burs that could be harmful to the tube.
Shawn Turner
01-08-2004 19:49:30
 Re: Re: Valve stem hole size for WD rim in reply to Mike IA., 01-08-2004 04:44:19
10-4
Thanks!
Shawn
