AC C rear rim clamps.
Burl
01-05-2004 13:50:32
I recently obtained an aftermarket set of rear rims that have four raised sections for the clamps to rest on. The stops for the one section are 4 inches apart,which seems excessive seeing that the clamp is only 3" long. The problem is that when the rim slipped under load, there is enough slippage that the clamps come close to coming off the raised section, and cock. Anyone else run into this? I'm thinking of welding another set of stops that are closer together, unless there's an easier fix. Thanks for any advice.
Dale
01-05-2004 16:41:29
 Re: AC C rear rim clamps. in reply to Burl , 01-05-2004 13:50:32
Oops, I have a 39 "B" that I am fixing up and just got a set of after market rims. I have just today, finished painting the clamps and am ready to order tires. I have not measured the one set of stops on the rims nor the width of the clamps. I do not really plan on using the ole girl for much work just playin. Will go out in the AM and measure. Would go now but its way to cold.
steve
01-06-2004 15:04:16
 Re: Re: AC C rear rim clamps. in reply to Dale, 01-05-2004 16:41:29
i just measured my 42 B, has about 3 inch width with 3 inch clamp inside. not much slop.
CHALMERSBOB
01-06-2004 19:09:40
 Re: Re: Re: AC C rear rim clamps. in reply to steve, 01-06-2004 15:04:16
CHECK YOUR CLAMP ARRANGMENT. THE CLAMPS AT THE LOCKS SHOULD BE THE FIXED TYPE WHICH ARE SMALLER THE THE CAM LOCKS. MAYBE BY PUTTING A CAM LOCK CLAMP AT THE RIM LOCKS IT WILL TAKE UP THE SLOP.
JUST A THOUGHT LOL BOB
