E-Gleaner in a WD?
Scott Hancock
01-04-2004 15:38:33
What pulley do you use on the front and what clutch and flywheel assembly do you use to put the gleaner in a WD?
pj
01-04-2004 18:16:19
 Re: E-Gleaner in a WD? in reply to Scott Hancock, 01-04-2004 15:38:33
I used the wd pulley after I bored it out,and water pump.And I also used the wd clutch & flywheel.The water pump bolts are different sizes.
Scott Hancock
01-05-2004 17:24:32
 Re: Re: E-Gleaner in a WD? in reply to pj, 01-04-2004 18:16:19
so it has to be milled out on the end so it will fit all the way up to the set screw hole? thanks!
