Mr. James, whether you're holding the button or not doesn't matter, there should be a neutral somewhere between low at the rear position and high in the forward position. True, the button would hold it in neutral as a convenience, but the button has nothing to do with whether it actually goes into neutral or not, that happens inside. That clutch is a little like your MF in that it stops the forward motion of the tractor but allows the PTO to continue. The WD and WD-45 clutches did that too. But they did not have the high and low feature incorporated. So what you have is two clutches in one. When it's in high, or forward, the drive is direct as if it didn't have the clutch at all. But when you go into the rear position, or low, it disconnects the high clutch and activates the low clutch which is connected to some reduction gears, and there's your low. It's sure not complicated, but it does have to be like Allis-Chalmers says, or all kinds of things can crop up, like you see. If you're very interested in the tractor all you need do is get someone to go in through the small plate on the side by the lever and adjust the clutch according to the book, which is a procedure that must be done correctly, but it doesn't take long and is no big deal. Anyone that's not familiar with the clutch or that doesn't have a manual to go by can not do it. It's a matter of moving shims around and it has to be done right. For example, the same specified total amount of shims must always be present, but moved from one of the three locations at each ear to the other after taking measurements inside. Additionally, the center shims have longer legs for support. It sounds terrible, but it's not, just has to be done right. It is not a simple matter off just going inside and tightening something or removing some shims. There's a definite procedure that must be followed. Then, If the clutch won't adjust or the adjustment doesn't help obtain a neutral, then you may have more on your hands than you'd want to fool with, because the tractor may have to be split for the clutch repair. The kicker is whether it's just out of adjustment, meaning maybe somebody messed with it not knowing what they were doing, or whether something really is wrong. Do the easy thing first by getting it adjusted. After that you'll know what to do. If I can help, let me know. God Bless. Pon
