high side trouble in a d17
tah
01-03-2004 17:10:17
Just purchased a 17 stays in low side fine but wont stay in high side. Tried to adjust handle from outside is there anything I can do through the small plate behind the handle
JoelMN
01-05-2004 15:25:15
 Re: high side trouble in a d17 in reply to tah, 01-03-2004 17:10:17
Probably needs ramps and rollers in the clutch unit. If so then need to split.
Pon
01-03-2004 17:48:19
Tah, that's where you do what you can, through the small plate. Try to get hold of a manual for it is a certain procedure that has to be done right. Somebody may have beat you to it and you'll have to get it back straight. Most times, the proper adjustment through that plate will do the trick. If not, it's a tractor splitting, bigger deal. Let me know if I can help.
God Bless
