WC/D17 engine swap question
slowsmoke
01-01-2004 11:01:32
I'm dropping a D-17 motor into a WC, which cooling system/water pump should I use? 17 motor has bypass, but the WC's water pump is new, and lines up to radiator. Just useing as a puller. Thanks, Don
Kip[UT]
01-01-2004 22:44:34
 Re: WC/D17 engine swap question in reply to slowsmoke, 01-01-2004 11:01:32
Use the WC water pump & water manifold set-up, because your WC has a non-pressurized radiator.If you have a styled WC could use a later WD45 radiator w/ pressurized cap & use the D17 pump & manifold.
slowsmoke
01-03-2004 05:48:19
 Re: Re: WC/D17 engine swap question in reply to Kip[UT], 01-01-2004 22:44:34
Thanks, wc water pump it is. will the wc's manifold bolt on the taller head? I'm not an orange tractor guy. Don
slowsmoke
01-03-2004 05:47:54
Thanks, wc water pump it is. will the wc's manilof bolt on the taller head? I'm not an orange tractor guy. Don
Chuckster
01-03-2004 07:33:14
 Re: Re: Re: WC/D17 engine swap question in reply to slowsmoke, 01-03-2004 05:47:54
Yes it will but if you still have the D17 manifold and carb.That would be your best setup.Good luck!
Kip[UT]
01-03-2004 10:50:02
 Re: Re: Re: Re: WC/D17 engine swap question in reply to Chuckster, 01-03-2004 07:33:14
I think you mean the water cross-over manifold. Yes it will, & top hose should still work just fine.
