Smaller models
Scott Hansen
04-21-1999 14:59:15
Which AC models are small, comparable to the 8N or Farmall A or B. Looking for second tractor. Is there a good web page to browse?
Brian
04-29-1999 21:20:15
 Re: smaller models in reply to Scott Hansen, 04-21-1999 14:59:15
The CA would be a little more than an 8N but the Ford has one advantage here. It has a 3pt hitch. The A-Cs can be retrofitted but all the kits I've seen to do this have been $300 to $500. All depends on what you need to do with it. Hope this helps. Brian
Dave Fullmer (TN)
04-22-1999 14:20:57
In my opinion, the AC B, C, or especially the CA is in the same power range as the 8N Ford. The CA will outwork the 8N any day of the week. A WD or WD45 is such an improvement in power over the 8N that there is no comparison. There is a good small book in the archives on this site that really does a good job of describing the small ACs. Go to article archives and look up the Little ACs. Good luck.
Ed Kiburis
04-21-1999 17:46:21
I have a 1948 A-C model C that originally put out about 15 to 20 hp. Not sure how much it puts out these days. I added an after market 3 point and use a 4 foot rotary cutter, a 5' box scraper and a one row tine cultivator on 10 acres. It seems to do quite well. This is my only tractor. If I had it to do over or needed another I would probably go for a WD-45 which puts out about 30 hp and are reasonably priced.
The A-C B, C and CA are the small, older, tractors.
Dan D.
04-22-1999 04:56:20
 Re: Re: smaller models in reply to Ed Kiburis, 04-21-1999 17:46:21
The WD45 puts out 40 horsepower. It's a world of difference between these and an A or B Farmall.
Fred Wilke
04-21-1999 17:40:51
An Allis B or C would be a little smaller. A WC would be in that size range. I have a WC to sell and a B if you are interested. Good luck.
Scott Hansen
04-22-1999 06:57:47
 Re: Re: smaller models in reply to Fred Wilke, 04-21-1999 17:40:51
Location is the key factor, here. I'm in Utah, where are you?
Aaron
04-21-1999 16:16:35
Depending on how much money you have, there are several. The Allis Chalmers C, CA, WD, WD-45, smaller D series (10, 12, 14) all are in that range or a little bigger. Try the web page that should be with this post. There are a lot of AC guys smarter than me there.
Aaron
