Hydraulic System
Ron Farris
01-01-2004 07:10:59
My 1974 AC 160 leaks air around the Hydraulic pump seals. It is an Aeroquip hyd pump on a Perkins diesel. I installed a needle valve on the suction side of the pump to bleed off the air, this allows the hydraulic trip bucket and lift arms to work again...I am told the aluminum Hyd pump is notorious for leaking around these seals...I bought a new pump @ $600.00 and now it is doing the same...is there a replacement pump that is better made? Like out of steel? Is the Massey Ferguson 255 Perkins diesel engin Hyd. pump interchangeable?
