WD45 DIESEL
Jerry
12-30-2003 10:52:14
I have a WD tractor that I put a 45 Diesel engine into. The combination does not work well. No power on the pto. Smoked out neighbor hood trying it out on flail chopper. And to fast in 1st gear. I need to get WD45 Diesel running gear to put this engine into or find a complete tractor. Thanks, Have a happy New Year, Jerry 715-689-2433
ken sampson
01-01-2004 19:33:21
 Re: WD45 DIESEL in reply to Jerry, 12-30-2003 10:52:14
Go to olestractors.com They have a wd-45 listed for sale.
Jerry
01-01-2004 23:10:30
 Re: Re: WD45 DIESEL in reply to ken sampson, 01-01-2004 19:33:21
Ken S.; Whew!! Just got back from Ole's place. Nice looking WD45 DIESEL but now I need to win lottery. Cheaper to buy D-19 for $4500 than 45 for $4900. I think me play with 45/wd for now. - Steve Ga., more horsepower?, More like over loaded. - Mark, Some of info I got came from a 1956 The TRACTOR FIELD BOOK, some from an old A-C dealer many years ago and from a Thompson booklet. Then of course the differences in gearing right out of A-C parts books. Thanks guys, remember if you run across something I can use to make a decent 45 Diesel, let me know, thanks again Jerry
Jerry
01-01-2004 23:45:39
 Re: Re: Re: WD45 DIESEL in reply to Jerry, 01-01-2004 23:10:30
Mark?? I'm sorry, I meant Tom. I must have to much smoke already btween ears. Any where to direct you to for hard info? Don't know myself. Are you an A-C man? -- Phil M., Yup those Cockshutts had the same engine in their tractors too.
PDA
01-01-2004 17:45:57
The wd45d had a differt ring and pinion to work with the extra rpms. Best bet to find a wd45d tractor without engine. These tractors are becoming rare. I think AC only built like 6000 of them.
Steve-Ga
01-01-2004 15:23:35
You simply have a WD with more HP?
Tom
12-30-2003 19:50:36
Jerry, If I recall correctly, the diesel engine was rated about the same HP as the gas, but the rpm was higher on the diesel. The adjustment for setting the rpm is on the outside of the pump. Slow it down a few hundred rpm and your ground speed will correspond accordingly. If it is smoking excessively, the power (fuel) adjustment may be delivering more fuel than it can burn. This adjustment can be accessed without removing the pump also. Try reducing the rpm and the amount of fuel as a starting point, and see if this corrects your two problems. Tom
Jerry
12-31-2003 00:00:22
 Re: Re: WD45 DIESEL in reply to Tom, 12-30-2003 19:50:36
Hi Tom, Thanks for the ideas. I could slow the engine down just on the throttle, but now the engine turns to slow. As an industrial engine they turned 2400 rpm at 60 hp. free load was 2700. If I remember right, max torque was 156 @ 1400 but now the engine is under full load. These engines ran years trouble free at the upper speeds but A-C slowed the engine down to accommodate the tractor and even put special gears in it to keep the rpms up higher (1625) than the gasoline engine (1400). But now that engine was over loaded all the time. Like any engine, if you overload, they dont last as long. My theory here anyway. At the moment the injectors are out and been serviced. Ready to go back in. Then check timing of pump to engine. Then see if its fuel screw. Would like to have a 45 running gear that doesn't howl like those straight cut gears in the wd. Or aquire an actual WD45 Diesel to enjoy. Thanks and have a good new year, Jerry
Tom
01-01-2004 03:58:48
 Re: Re: Re: WD45 DIESEL in reply to Jerry, 12-31-2003 00:00:22
Jerry, I admire your determination to make the diesel work in the WD! Taking one step at a time as you are doing should enable you to locate the problems. I have seen a few 226 gas engines replacing the diesel, but not the other way areound. We have a WD45D and use it for a variety of tasks. The history you metioned transforming the Buda 230 from an industrial application to agriculture was interesting. I have been unable to locate any material to reasearch on this engine and what AC did to adapt it. Do you have anything you can direct me to? Tom
Phil Munson
01-01-2004 14:29:34
 Re: Re: Re: Re: WD45 DIESEL in reply to Tom, 01-01-2004 03:58:48
Same animal as in the cockshutt 40D. The one I had worked well at just slightly more than half of the 2700 RPM figure.
