WD-45 stuck in gear
Chuck
12-30-2003 07:22:06
My WD-45 is stuck in first gear. I can move the gear shift to any position without depressing the clutch and I am still stuck. I am not anxious to remove the transmission nor do I want to spend the big bucks at the dealer. The first time it happened a neighbor removed the gearshift and poked around with a screw driver and suddenly it was unstuck. He is not available now. Suggestions?
DAVE
12-31-2003 17:46:27
 Re: WD-45 stuck in gear in reply to Chuck, 12-30-2003 07:22:06
IT SOUNDS LIKE YOUR NEIGHBOR FOUND YOUR TROUBLE WITH A SCREWDRIVER. inside the transmission there are slider shafts on those shafts there are shifting forks also there will be a mechanism that moves the shafts and forks back and forth.make sure the forks are tight to the shafts and there is no slipage and that mechanism on the end of gear shift is not wore of and intact. check these things good luck...
Jerry
12-30-2003 11:11:38
Yup, BRyan has been there and done that. Now try that trick in the middle of the night, no flashlight, no long screw driver, just jackknife and electric fence post. This fall I was combining with a D17. Having to stop and back up often, the shift stick took a strange feel to it, It would go into neutral while in gear. You could fish around and get shift stick back into position to shift. Finished last field and put it in road gear and couldn't get it out until I got home and pulled the shift cover off. Found out it was a broken tang on the center shifting rail.
Lee
12-31-2003 07:29:43
 Re: Re: WD-45 stuck in gear in reply to Jerry, 12-30-2003 11:11:38
We had a WD-45 that did that all the time Dad had the cover and rails rebuilt but it didn't do any good. We had to line up the rails into the neutral position then put the shift lever back in.
The shift lever needed to be rebuilt.Good luck.
Lee
Scott
12-31-2003 03:17:15
Try doing it in front of about 1000 people at a tractor pull. When I was a kid I was pulling our old WD and tried shifting too fast when I was backing into the sled. The only solice was that I won that night. I wish we still had that old girl. She didn't look like much. But boy did she pull on the track.
Bryan Smith
12-30-2003 08:54:54
Do what the neighbor did - it's not hard.
(1) Block the wheels and make sure pressure is off the transmission - you don't want it rolling on you when it comes out of gear.
(2) Remove shift boot.
(3) Look for the snap ring holding the gearshift down inside the shift tower. Use a flat screwdriver to remove it.
(4) remove shift lever gently. There are some spring loaded pins (one side or both sides of the lever) that fit in the grooves on the shift lever ball - just don't want these to fall into the tranny.
(5) Use a flashlight and look inot the shift tower. If it's stuck in first look toward your left. You'll need a large scredriver or small pry bar. Move the shift collar back up to the middle so it's in line with the rest.
(6) If you can do so *safely*, gently roll the tractor back and forth by hand to make sure it's out of gear. If the shift collar is in the center it will be out of gear, though.
(7) reassemble the gear shift.
The shift collar will make sense when you look in there. Remember, you move the gear shift to the left and up to get into first, so the part of the lever that is down in the tranny moves to the right and down. That's why you're looking to thr right side and trying to move the shift collar up.
Hope that helps - it's not definitive but it gives you the general idea. Be careful, be safe, don't let the tractor roll over you. Use blocks!
Bryan Smith
12-30-2003 08:56:16
 Re: Re: WD-45 stuck in gear in reply to Bryan Smith, 12-30-2003 08:54:54
(5) should say look toward your right - sorry for the typo!
Lee
12-31-2003 03:08:03
 Re: Re: Re: WD-45 stuck in gear in reply to Bryan Smith, 12-30-2003 08:56:16
Bryan is right!!!But while you have the shift lever out either do it yourself or have someone who can braze a coating of brass around the bottom of shift lever that moves the slidders in tranny, I've did this many times on AC's that I've had and it it works every time. Put about 1/6 th or 1/8 th coating on it, or put another shift lever in that is not worn as much as yours is.
