good uses for WD45 ?
Jo
12-29-2003 11:42:55
Am looking at buying a WD45 for acreage for belly-
mowing and loading. This one is a narrow front end with a two point hitch. Will this tractor work for me. Am not familiar with AC two point uses. The tractor comes with no implements.
Loren NC
01-09-2004 13:13:11
 Re: good uses for WD45 ? in reply to Jo, 12-29-2003 11:42:55
There is one thing that nobody has addressed for you. After you mentioned that you are not familiar with the AC two-point hitch, somebody should have told you that they are REALLY three point. If you look under the belly of the tractor you will find a cup-like attachment where the front end of the drawbar is inserted. That is a snap coupling that serves as the third point for AC implements. As somebody noted, those types of implements are fairly common, but it is also fairly easy to find a "normal" three-point hitch that hooks right into the three points on the Allis and lets you use anybody's equipment.
Wayne
01-01-2004 08:09:38
I have a 1953 WD and use it for every thing. Mine has a wide front end. I have some of the Snap-couple impelments and have also made a 3-point hitch for it.I don't have a belly mower, but with the HP that the WD-45 has it with do a great job for you. The uses that I use mine for are the following baling, plowing, discing, spraying, bushhogging, blading, just a good all arond tractor. If I were you, I would go with a 3-point hitch finish mower, it would be a lot easiler to put on and take off when you wanted to use the tractor for other uses. The Allis that I had before this one was a narrow front and there was uses that I like it better for, but over all the wide front end will serve you better. One of the jobs that I liked the narrow better is mowing, the tractor will turn sharper.
Wayne
Jo
01-01-2004 08:53:32
 Re: Re: good uses for WD45 ? in reply to Wayne, 01-01-2004 08:09:38
Thanks for the info Wayne. Will start looking for the 3 point.
John (C-IL)
12-29-2003 18:37:20
A WD45 will make a powerful belly mower tractor although the C and the CA are more popular. An endloader will work alright on the WD45, but it has one way hydraulics so you are stuck with a trip bucket unless you add a pto or motor pulley hydraulic pump. The snap coupler implements are relatively plentyiful in the midwest, it just depends where you are.
mojo
12-29-2003 16:12:29
don't know how well a belly mower works (i use a b farmall for that) on a wd, but the narrow front would be better than a wide front.
for a loader a wide front would be better, but if you're careful a narrow front is alright.
as for the snap coupler hitch, 3 pt conversions can be had or buy original equipment, whichever is cheaper in your area.
