d17 wont start
fw
12-29-2003 06:05:06
took out jets and cleaned with carb cleaner, while carb was off cranked over engine and held hand over manifold, plenty of vacuum. tested
commpression 80lbs each cylinder. replace condensor, cleaned points, pulled off plug wire and cranked engine will spark 1/4" to ground. i can spary starting fluid in manifold and still nothing. also checked timing #1 piston up all the way ,rotor points to one on the dist cap.
what am i missing??
old
12-29-2003 08:51:41
 Re: d17 wont start in reply to fw, 12-29-2003 06:05:06
The compression is low it should be up around 120psi. You might get it to start if you would pull it
