allis b carb [help]
decker in ny
12-28-2003 18:59:15
HELLO JUST GOT THIS TRACTOR NOTTA A BAD BUY THE PERSON I GOT THE TRACTOR FROM HAD SAID JUST REBUILT THE CARB. THIS THING FLOODED OVER BAD I PULLED IT APART FLOAT WAS STUCK OPEN GOT THAT FIXED IT RUNS FINE FOR ABOUT 30 SECONDS STILL ACTING LIKE IT FLOODING OUT DONT KNOW IF THEY DRILLED THE JETS OR SOMETHING AT AN IDLE IT RUNS FINE BRING UP THE RPMS ACT LIKE THE CHOKE IS ON BLACK SMOKE ROLL OUT OF THE EXHUAST BREAKS UP BAD ANY HELP GREATLY NEEDED
steve
01-01-2004 14:00:38
 Re: allis b carb [help] in reply to decker in ny, 12-28-2003 18:59:15
sounds like the carb,but you might want to check the timing also. higher RPM will make the advance kick in and you might be too far retarded at high speed.
