What gasket/seal is it
weekendwarrior
12-28-2003 12:24:11
On a WD-45, gas engine, next to the oil pan there is a cover about 15" wide, 7, 7.5" tall. Held in place with 4 1/2" bolts, possibly covering the transmission. What do you call the gasket/seal that is used to keep the dirt/snow out? I need to find one.
thanks!
JMS/MN
12-28-2003 12:37:44
 Re: What gasket/seal is it in reply to weekendwarrior, 12-28-2003 12:24:11
Do you mean the half-moon shaped formed sheet metal cover? Just to the rear of the oil pan- you could call it the clutch/flywheel cover. It does not have a gasket on it. No need for one since it is a dry clutch.
weekendwarrior
12-28-2003 17:30:16
 Re: Re: What gasket/seal is it in reply to JMS/MN, 12-28-2003 12:37:44
Don't I need to worry about the dirt getting in there?
JMS/MN
12-29-2003 19:02:08
 Re: Re: Re: What gasket/seal is it in reply to weekendwarrior, 12-28-2003 17:30:16
Not to worry as long as the steel cover is in place. After all, there are other holes in the casting around the flywheel that there are no covers for.
