Allis CA compression
John
12-28-2003 04:48:51
My CA has 100 LBS compression on all Cylinders, is that good compression. Also will a B or C cylinder head fit the CA. I am getting lots of smoke after it idles. Been told that oil is being sucked down thru guides.
Thanks ...John
Lee in MI
01-01-2004 05:54:41
 Re: Allis CA compression in reply to John, 12-28-2003 04:48:51
Do another compression check with a little oil in the cylinder and see if it reads the same. If it increases only a little than the guides are most likely the problem, if it jumps alot than the rings are letting the oil by.
Phil Auten (TX)
12-28-2003 14:13:43
Rebuilding the head will probably be your best bet here. Any competent machine shop should be able to handle this with a minimal outlay of $$. Replacing a head might fix it, but unless you are able to check out a cylinder head to see if it is in good shape, you might not get a better head than what you have. Some folks will tell you their head has been "completely rebuilt", when in actuality, it's just been cleaned and painted.
Phil
Dick L
12-28-2003 07:08:29
The heads will work. You can mix and match engine parts on all four engines. B, C, CA, and RC.
