allis b timing
tim
12-27-2003 15:51:32
i just put a rebuilt mag on my 1950b allis model b and it runs fine other than it seems to have a loping sound, the engine idles up and down. is this the timing and how do i time this tractor. thanks in advance. tim
Dale(MS)
12-27-2003 19:00:34
 Re: allis b timing in reply to tim, 12-27-2003 15:51:32
Tim, Might need an anti-surge spring on the carb. Watch the throttle shaft that goes to the carb and see if its moving, kinda hunting for the right amount of fuel. Stop its movement with your hand. If it smooths out the spring would probally help. If thats not it, it could be in the governor,etc. Dale
Duey (IA)
12-27-2003 16:23:23
Tim, Timing a mag. (FMJ)
1. If you have taken the Mag. apart, the internal gears need to be timed. (Set points at .020)
2. Remove the large cap and line the C mark on the fiber gear with the marked tooth on the steel gear. Tip- turn the engine backwards to get the steel gear tooth to stop straight up and position the C mark on the fiber gear straight down. This times the rotor to the points. It is pretty simple in theory. Like all four cycles, the piston comes to TDC (top dead center) twice for every time the magneto or distributor rotor goes around. ("B"&"C")The left side of the engine has a hole in the bell housing where you can see the timing mark on the flywheel. ("WD" &" WD45" The timing mark is found by looking under the flywheel housing for a small hole possibly covered by a small plate held with two wing bolts. The FIRE mark and the TDC mark are located on the flywheel through this hole. Use a little light colored paint to make seeing them much easier). 3. Take out the #1 spark plug, and put your thumb over the hole while hand cranking the engine(best to have all the plug wires off while doing this so the tractor doesn't try to fire) , the cylinder will force air past your finger on the compression stroke. (The other FIRE is the exhaust stroke and has the exhaust valves open so no air will come out of the plug hole).
4. When you feel the air coming past your thumb, look for the FIRE mark on the flywheel. When this mark is centered in the hole, the rotor on the mag should be just lower than the #1 lug on the mag. Looking at it as a clock, #1 lug should be near 10:00. Just before the lug is a plastic stud called the timing stud. Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole. 5. If your rotor points to 5:00 your mag is 180 degrees off and needs to be removed and the coupling turned till you achieve 10:00. If it is not right on the timing stud, you can loosen the mag and rotate it until it is. 6. Put it all back together and time your spark plug wires 1-2-4-3 clockwise on the magneto cap.
Remember if the rotor is aligned with the timing lug when the fire mark is in the window, you got it right. If it's not quite aligned when the fire mark is in the hole, then you rotate the mag clockwise or counter clockwise until it is. Remember Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole. Duey
