NEED HELP WITH CA WIRING
JAMES
12-27-2003 15:19:15
I HAVE A 1951 ALLIS CHALMERS CA ALL WIRING IS MISSING. TRACTOR HAS A DISTRIBUTOR AND STARTER HOWEVER THE COIL, GENERATOR, AND IGNITION SWITCH AND ALL WIRING TO THESE COMPONENTS IS MISSING. I PLAN TO CONVERT TO 12 VOLT ALTERNATOR BUT I NEED ADVICE ON PROPER WIRING DIAGRAM FROM IGNITION SWITCH TO STARTER TO COIL. IF YOU CAN HELP PLEASE RESPOND. THANKS, JAMES
steve
12-27-2003 17:30:54
 Re: NEED HELP WITH CA WIRING in reply to JAMES, 12-27-2003 15:19:15
one other thing that works good, is to install a key or push button starter switch. put a solenoid off an old ford truck and wire to your 6 volt starter. i like the push button and a kill button for a mag. with a coil, you might do it with a key switch, or a toggle and push button.
steve
12-27-2003 17:27:38
James, send me an e-mail and i will send you a diagram. Might be able to find one of Dueys on this page also. 12 volt is nothing complicated. use the same wireing diagram as the 6 volt. remove the 3 way light switch wire to generator and the generator cut out switch, and install the alternator. any alternator with an internal voltage regulator is o.k. (simplier wiring if internal). [email protected]
David Owen
01-15-2004 08:28:32
 Re: Re: NEED HELP WITH CA WIRING in reply to steve, 12-27-2003 17:27:38
I need help with rewiring a WD45. Do you have a wiring diagram? I'm restoring a 1956 and the wiring is completely shot. It has the voltage regulator conversion instead of the relay, but going back to the original is preferrable. Thanks,
Dave Owen
[email protected]
1021 N 680 Rd
Baldwin City, KS 66006
785-842-1643 Fax 785-331-2518
