Older 201 Leroy Fox chopper engine
M. Gard. (WI.)
12-26-2003 17:40:52
I have a 201 Leroy engine out of a older Fox field chopper. The intake and exaust manifold is different on this than on a 201 in an Allis Chalmers WD. Will these manifolds interchange? The carburetor also seems to be different on this than on a WD. Any information would be much appreciated.
Thank you.
Chuckster
12-27-2003 05:50:02
 Re: Older 201 Leroy Fox chopper engine in reply to M. Gard. (WI.), 12-26-2003 17:40:52
I had a leroi air compresser with the 226 motor we had rebuild it the only thing we had to change was the crank and cam (we had the cam reground and we had problems with the grind so we put the orridginal cam in it) and the water pump. In a D17and she runs really well. Have a happy New Year
Justin
07-20-2004 06:14:00
 Re: Re: Older 201 Leroy Fox chopper engine in reply to Chuckster, 12-27-2003 05:50:02
Would you happen to have the flywheel ring gear from the Leroi motor yet? I Need one of them The tooth count is different on the leroi flywheel.
AZ Jack
12-26-2003 19:30:31
I am inclined to think that they will interchange. I have a LeRoi Tractair and a WD45 and as near as I can tell from external appearance the manifold and head would both interchange as would the water pump also. The LeRoi has a wet manifold but the bolt pattern appears to be the same. Hope we get more replies-would like to know for sure myself-Jack
