WD Hydraulics
Jeff
12-25-2003 09:42:40
Can anyone tell me how to set the WD up so I can turn the front or rear Hydraulics off and on independently? I'm putting a three point conversion on the tractor and keeping the bucket on the front.
Thanks in advance
JMS/MN
12-26-2003 12:30:10
 Re: WD Hydraulics in reply to Jeff, 12-25-2003 09:42:40
The cheapest solution is to put a brass water valve in the line coming out of the pump, going to the loader hose. Ones we got years ago stood up to the line pressure. Shut if off with the loader at the height you want it, and use the lift arms.
steve
12-25-2003 11:19:59
i bought a two way selector valve to do this to my C several years ago. this is a single spool push pull valve. the pump hose goes in the supply, and you have two outlets, one to the front and one to the rear. dont know if they are still in business, but i got mine from "Surplus Center" 1-800-488-3407, the part was 9-004. it had 1/2 inch pipe in and out ports. mounted juste below the seat so i can push- pull easily to change oil route. when you pull it out it lockes 3 point in that position while you use the bucket, etc.
