AC 180 Brakes
J I CASE
12-23-2003 17:03:32
Ok I got to put new brake lining on my AC 180. Now how in the world do you get to them ?? That small hole in the bottom and that pin alway the way across kind of has me puzzeled. Would appricate so of you old head on AC to advise me, thanks ,
Ossie Smith
JI Case
jerry
12-23-2003 23:42:22
 Re: AC 180 Brakes in reply to J I CASE, 12-23-2003 17:03:32
And don't forget to get the right spec.s before you put it back together.
oly
12-23-2003 21:26:16
ossie,, I would suggest you get a repair manual. To install brakes on the AC180-185 is not an easy job, you will need to block the rear of the tractor up, so you can remove the tires, wheels and final drives right in to the Differential carrier. then you can get at the brake system (a band/disc type). Also look all the parts over replace if needed and get two new seals (one for each side) for where the axels slide into the differential carrier. torque values are important too, so are cotter pins (don't forget them). I learned this the hard way.. good luck Oly
